*************************************************** REACTOR LOGIC SUMMARY REPORT ***************************************************
Version: 2.3 config 206 pluginDevice 90
Local time: 2019-03-24T18:39:28-0400, DST=1
House mode: 1
Sun data:
Geofence: not running
Power: utility, battery level 98
TEMP SET: 8AM M-F (#118)
Version 19012.1553466936 03/24/19 18:35:36
Message/status: Not tripped
Group #1 false as of 03-22.13:02:34
=f (comment) “MONDAY - FRIDAY AT 8:00AM: 66°F (HEAT) 73°F (COOL)” [false/false as of n/a/n/a; nil at n/a]
=f (weekday) { “id”: “cond169a4fddb52”, “type”: “weekday”, “value”: “2,3,4,5,6”, “operator”: “” } [false/false as of 03-23.00:00:00/03-23.00:00:00; 7 => 1 at 00:00:00]
=f (interval) { “type”: “interval”, “mins”: 0, “id”: “cond169a4feaa49”, “hours”: 0, “days”: 1, “basetime”: “08,00” } [false/false as of 08:00:15/08:00:15; 1553342400 => 1553428800 at 08:00:00]
=T (housemode) in 1,2,3 [true/true as of 03-22.15:07:51/03-22.15:07:51; 1 at 03-22.15:07:51]
Trip Actions
Device 99 (THERMOSTAT) action urn:upnp-org:serviceId:TemperatureSetpoint1_Heat/SetCurrentSetpoint( NewCurrentSetpoint=66.0 )
Device 99 (THERMOSTAT) action urn:upnp-org:serviceId:TemperatureSetpoint1_Cool/SetCurrentSetpoint( NewCurrentSetpoint=73.0 )
Untrip Actions (none)
Events
03/24/19 18:28:00 start:
03/24/19 18:35:36 configchange:
03/24/19 18:36:53 action: action=Reset
03/24/19 18:36:53 sensorstate: state=false
03/24/19 18:37:25 action: action=Trip
03/24/19 18:37:25 sensorstate: state=true
03/24/19 18:37:25 startscene: scene=__trip118, sceneName=__trip118
03/24/19 18:37:25 runscene: scene=__trip118, sceneName=__trip118, notice=Starting scene group 1
03/24/19 18:37:25 endscene: scene=__trip118, sceneName=__trip118
03/24/19 18:37:29 action: action=Reset
03/24/19 18:37:29 sensorstate: state=false
Local time: 2019-03-24T19:04:58-0400, DST=1
House mode: 1
Sun data:
TEMP SET: 4AM DAILY (#119)
Version 19012.1553468468 03/24/19 19:01:08
Group #1 false as of 04:00:15
=f (comment) “EVERY DAY AT 4:00 AM: 71.5°F (HEAT) / 69°F (COOL)” [false/false as of n/a/n/a; nil at n/a]
=T (weekday) { “id”: “cond169a626d1c3”, “type”: “weekday”, “value”: “1,2,3,4,5,6,7”, “operator”: “” } [true/true as of 03-22.12:10:43/03-22.12:10:43; 7 => 1 at 00:00:00]
=f (interval) { “type”: “interval”, “mins”: 0, “id”: “cond169a629e10f”, “hours”: 0, “days”: 1, “basetime”: “04,00” } [false/false as of 04:00:15/04:00:15; 1553331600 => 1553414400 at 04:00:00]
=T (housemode) in 1,2,3 [true/true as of 03-22.15:08:19/03-22.15:08:19; 1 at 03-22.15:08:19]
Trip Actions
Device 99 (THERMOSTAT) action urn:upnp-org:serviceId:TemperatureSetpoint1_Heat/SetCurrentSetpoint( NewCurrentSetpoint=71.5 )
Device 99 (THERMOSTAT) action urn:upnp-org:serviceId:TemperatureSetpoint1_Cool/SetCurrentSetpoint( NewCurrentSetpoint=69.0 )
Events
03/24/19 18:53:32 action: action=Reset
03/24/19 18:53:32 sensorstate: state=false
03/24/19 18:53:34 action: action=Trip
03/24/19 18:53:34 sensorstate: state=true
03/24/19 18:53:34 startscene: scene=__trip119, sceneName=__trip119
03/24/19 18:53:34 runscene: scene=__trip119, sceneName=__trip119, notice=Starting scene group 1
03/24/19 18:53:34 endscene: scene=__trip119, sceneName=__trip119
03/24/19 18:53:36 action: action=Reset
03/24/19 18:53:36 sensorstate: state=false
I don’t know what changes running the debug option, but after following your steps this executed properly. Both the UI of AVP and the variables updated to 68 for heating, 73 for cooling.
Since I was thinking I am crazy, I double checked the other schedules. The exact same set up (interval is now 4AM). The first trip action is set heat to 71.5, set cool to 69.0. When I tripped the sensor set both heat and cool to 69.0 in UI and in the variables tab.
If I go back and trip the 8AM Mon-Fri, it again executes correctly. I’ve restarted the plugin, tried everything to my little knowledge of this stuff but I cannot get both set points to update. I’m stumped.
Also, my reasoning for choosing the interval condition was to have the ability to adjust the thermostat manually without disabling the “program.” I plan to mount a cheap tablet on the wall where the Zipato was to have the Vera or Imperi app running. This way someone can easily turn up the heat (or cooling) in between the interval.
