[size=12pt]OCD ALERT - Unnecessary Extra Virtual Switches - Just because![/size]
I adapted the VSwitch plugin to suit my needs and wanted to make it available to all. I developed these to keep track of my X10 devices. But they can obviously be used for anything.
CREDITS: chixxi - it was his work I modified - reuse approval granted
RexBeckett, RTS and Brientim for guiding me passed all my mistakes.
[hr] CAVEAT: You must install the VSwitch Plugin. This is simply because I see no good reason in me duplicating the I_ and S_ file for the sake of it. Link:
[url=http://apps.mios.com/plugin.php?id=1408]MiOS Apps
[hr]
vPhone Location
This app shows a visual on the location of a phone… Simply Away/Home
in MIOS marketplace - awaiting approval?
vDoor/Window Sensor
vMotion Sensor
vAlarm Sensor
How I use these
I have my x10 Server send http commands to keep vera updated. I also have scenes in Vera querying some of these devices… It simply means I can react and control things from one set up/interface.
I like your idea to personalise the Virtual Switch , I was trying to think of any others you could do…
One that quickly sprung to mind was to have one for Heating, which shows if it’s On or Off, with the buttons being Heating On & Heating Off.(There can be a couple of ways for a heating/HVAC device to show if heating is on or off)
Sadly I have no room at the moment to install it to play with, but I wanted to ask if you’ve designed it to be a dynamic v switch? By that I mean you could set a variable so it could take on the form of any type of customised virtual switch (e.g iPhone, heating etc.)
I’ve been looking for a way to create virtual motion detectors (or virtual switches that appear as a motion detector) and I like your idea here. I saw the virtual phone plugin is available in the app marketplace but is your vMotion Sensor plugin available yet? Just wondering if it’s still in the works since I’d be very interested in testing that out.
I didn’t release the others as it took MCV two months to approve the first one… and I lost interest then…
I will post the files here for you when I get home…
From what I’ve gathered, this plugin was a work in progress a couple months ago despite being published to the app store. Unfortunately there hasn’t been any response from the developer konradwalsh on this thread for a while, but maybe he’ll see your post and be able to provide some info on it.
For what it’s worth I see the same thing if I install it.
