I have a timer to close the garage door in case it is left open. I want it to close the door by using the garage door app instead of the relay that triggers the garage door, but I can not get it to to trigger the locked position on the garage door. When the timer expires nothing happens.
For PLEG and PLTS issues … if you want help … post a status report in PDF
Here is the status report
