My office has two doors with a light switch at each door, so I have a 3-way setup using the GE/Jasco switches. I am using PLTS with a motion sensor to control the lights (report attached).
The issue I am running into is that when I turn the lights on or off via the auxiliary switch PLTS does not detect the event. If I turn the lights on or off via the UI or primary switch everything works as expected.
