I have a PLTS set up to close the garage door after 15 minutes if it’s night…in case I ever pull out and forget to close it. Last night though, I did forget and the door didn’t close itself…where should I start to see what went wrong? I do have a PLEG that turns the lights on when we come in, and that worked fine when we got home…and my PLTS worked just now when I lowered the timer to 30 seconds and opened the door. After half a minute, the timer went off and the door closed…so the switch itself is set up correctly…
Anyone have any ideas?
