PLEGS down - Need some help
I have 2 PLEGS, SENSORS, and Lighting. Vera reports a SENSORS LUA startup failure. Sensors had a lower device ID than LIGHTING.
Both PLEGS show no conditions, inputs, schedules, etc. I have restored from last night, and that did not resolve the issue.
The entire system is unresponsive, probably because of the Startup failure ?
Any advice on how to resolve this is greatly appreciated :slight_smile:
  1. In SENSORS … using the “LOG” button on the “Other” tab … Set the debug location to the Vera Log File.
  2. In another window open the Vera Log File:
    http://Your.Vera.IP.Address/cgi-bin/cmh/log.sh?Device=LuaUPnP
  3. Then back in the “LOG” panel select Reload LUUP
  4. Email me the log file … showing the entire reload cycle.
What type of Vera do you have ?
Are you having memory limitations ?
