PLEG / {(yourexpression)} in NewCurrentSetpoin
Hello Guys
I have problems with a variable in NewCurrentSetpoint. The variable is generated in Conditions and used to set heat.
What is wrong?
pleg_userexpression
You haven’t given us much to go on here. All I can say is the variable looks properly formatted.
You might post the status report in PDF.
I dont know what made the change. The syntax is correct.
