[quote=“RichardTSchaefer”]Forgot about that …
You might backup each PLEG device before you delete any Z-Wave device … then RESTORE after you rename the devices.[/quote]We’re does it actually back up to?
Sent from my SM-G950U using Tapatalk
Also, if I simply do a restore of an old backup without restoring the network would it accomplish the same thing?
[quote=“RichardTSchaefer, post:9, topic:197601”]You should not loose things … but the changes will not happen until the next reload.
If you close the edit window … and then open the edit window again … it should refresh the data from Vera.
Make sure you have the latest PLC and PLEG version.[/quote]
I’m having similar problem of PLEG changes not being saved.
I’m working with PLEG for around 3 years. This is my main tool with more or less 100 conditions, and never had this problem.
PLEG ver - 7.47
PLC ver. - 7.48
Vera Edge - UI7 latest firmware - 1.7.3500
I had a call with vera support, with no issues found from their side.
Any ideas what can cause this?
Thanks,
I have the same issue - PLEG doesn’t save any changes I make (tried changing a condition and tried changing a LUA code within an Activity).
I have moved from one VeraSecure to a new VeraSecure (using backup & restore), due to a VeraSecure battery problem.
Any idea how I can make PLEG save changes?
I upgrade to the new generation PLEG and everything works great again.
BTW, I had the same issue with battery on my new Secure and just sent the all unit for replacement after it stopped working…
