I just put in some motion sensors and have them working for the most part. The issue is if I manually turn off for example my powder room, then the motion trigger does not work to turn the lights and extractor back on. What am I missing? The Status PDF is attached.
Might be the time out of the sensor, do you know what they are set at?
How do I check the sensor timeout? They are Dome Motion and Light Sensors.
Just figured it out. Thank you for the help!
