I have a bedroom with a motion (occupancy sensor) and Fibaro dimmer using pushbutton switch. I’m using Richards PLEG setup “Basic Light, Motion Sensor, Night Time Example” for this light.
If you are in bed sleeping, and move, this trips the motion and on go the lights. So what would be a solution to keep the lights off during sleeping times? The thing is this is a guest bedroom. There is no set times someone may go to bed. Different people, different times. Any ideas how to best deal with this? I actually have 3 bedrooms I need to do this on.
The motion sensors are actually connected to my ELK panel and are devices via the ELK plugin for what that info is worth.
I was thinking about a push button sequence that would put the motion to sleep for say until it is “Day”. But one issue with Richards light scheme is that the pushbutton doesn’t seem to do anything (AutoOnLight1) because the motion is in tripped mode during the 15 second timeout.
Any ideas???
