So I have a schedule that failed to trigger last night.
It is set up correctly as far as I can tell.
Anyone know why this wouldn’t have run when it was supposed to?
sDimTime is the schedule in question.
Thanks. I’ll give that a look.
I had assumed some logic was built in that would evaluate those schedules to ensure they were True during the specified time frame regardless of controller activities.
I suppose this means my sNight schedule could fail as well? Or is that not considered absolute since i’m using sunrise and sunset?
If Vera was reloading at at 10PM … and it finished loading at 10:00:10
Then it would schedule the for 10 PM the next day.
I still have not checked to see if Vera implemented the changes I requested that would allow me to handle this case cleanly.
I wasn’t performing any activities on it that would have caused it to reload to my knowledge at that time. I don’t think I was even logged into the interface. But it’s only done it that one time. It has not done it since and it’s been quite a few days.
If you can post the entire status report (example attached), the community may be able to help you. It may not be a schedule issue. What Richard was saying is Vera could have been restarting LUUP which on my unit can be 2 or 3 times a day without user action.
