PLEG problem with armed/bypassed Fibaro door sensor
I remember having read something about this but cannot find it any more.
I have a Fibaro doow window sensor. I created triggers in PLEG for this sensor, one for armed the other one for not armed. But even when the sensor is bypassed and triggered, both conditions go true at the same time
See:
http://forum.micasaverde.com/index.php/topic,16125.0.
Thanks, i knew there was something, just couldn’t find it any more
The fix is waiting MCV audit.
Fixed … See:
http://forum.micasaverde.com/index.php/topic,14447.msg123532.html#new
I have updated my PLEG to 4.6, just tested it, and it still triggeres armed when the door sensor is bypassed
You will have to edit at least 1 trigger in each PLEG device that uses the ARMED SENSOR triggers.
ok, would it work if i delete them and put them back in or just rename them ?
