This is my setup
When I am away (Mikeaway) a multi switch is switched on (Test Multi Switch SetStatus7 newStatus7=1) that works
when i am coming home (Mikehome) a scene runs (94) which turns the multi switch 7 off, and multi switch 8 on. Although the condition was true 18:24.794, it did not change any of the multi switches. (7 was on, 8 was off, before Mikehome was triggered). Before i had the scene, i used action to turn the switches on/off, but as that did not work i tried it with a scene, without success. When i just run the scene, the scene switches the multi switch. I cannot see why.
Lighting PLEG
Device ID: 2212013-10-13 18:29:14.578 PLC Version: 5.1
Triggers
Name Description Last Trigger State
Mikehome (*)Mike is present 2013-10-13 18:24:52.794 false
PingMike Ping Mike is Tripped 2013-10-13 18:25:55.250 false
Device Properties
Name Device Name Device Variable Last Change Value
Mdistance1 ()Mike Distance 2013-10-13 18:29:03.709 0.009
Jdistance ()Justine?s iPhone Distance 2013-10-13 18:21:58.283 0.014
Mdirection (*)Mike IconCode 2013-10-13 18:29:03.812 100
Conditions
Name Expression Last True State
Mikeaway Mdistance1 > 2 2013-10-13 18:24:36.467 false
Mikehome Mikehome and PingMike 2013-10-13 18:24:52.794 false
Mikenotaway Not (Mdistance1 > 1) 2013-10-13 18:24:52.778 true
Mcomhome (Mdirection == 75) and Mdistance1 < 2 2013-10-13 14:17:46.957 false
Actions
Actions for Condition: Mikeaway
Immediate
Device Action Arguments
Test Multi Switch SetStatus8 newStatus8=0
Actions for Condition: Mikehome
Immediate
Lighting PLEG RunScene SceneNameOrNumber=94
Actions for Condition: Mcomhome
Immediate
Test Multi Switch SetStatus3 newStatus3=1
