I’m having a problem with a test PLEG in so much that it does not evaluate the condition(s) as they become TRUE.
I’m not seeing why and hope the wider PLEG community can offer a solution.
The Test PLEG could not be simpler, it’s based on the Heliotrope Plug In.
I have used a property to return the Azimuth, which i turn I have created a Condition which is then used to test when the Azimuth moves through set points of the compass.
In this case I am testing for 0,90 & 270. (90,0,270 which is the correct order of the travel of the Sun.
Over the past 3 weeks I have tried every combination I can think of, such as =, ==, eq, etc in the Condition Test. = returns a null, while == & eq only return a last false and no last true.
I have also tried this with Repeats On and Off.
I have tried to place express values as “90” or 090 and so on with no success.
The Test Pleg has been running for 7 days, in which it has never evaluated the Test Conditions even though the pAzimuth & cAzimuth return values.
Status report attached. If anyone has any ideas, I’m all ears.
TIA
