currently using 1.7.4453 on a veraplus, and finding recently, that even though conditions are marked as true, the corresponding actions are not firing.
To try and combat this, taken a copy of the logic and created a new entry, importing the logic etc, and now this is suffering the same issue. Note, these conditions have not been changed recently, and hence, it shouldn’t be a case of the condition being true before the expected actions performed.
I’ve tried reloading LUA from the editor menu and also tried ‘Reload Engine’, but still seeing the same.
I’m considering a move across to Reactor, but will need to review the logic, as its all nice and neatly packed into individual pleg entries currently, and reactor appears to need to have them split out into particular actions based on a single set of criteria.
Anyone else seeing similar?
