Mios is at 100%, as is the dev/root. If this isn’t due to Pleg, then I don’t want to muddy up this thread, and I’ll lean more heavily on VERA.
Registration
Installed: Sun Feb 16 2014. You have 1 license, which allows a total of 4 PLEG and/or PLTS plugins.
Triggers
Name Description State Last True Last False
BDOpen Whenever Back Door Sensor is opened whether is armed or disarmed false 2016-06-11 12:26:17.166 2016-06-11 12:26:27.156
BDPINEntered PIN Code #* is entered on Back door true 2016-06-02 22:40:23.346 0
BDUnlocked Back door is opened true 2016-06-11 06:49:13.777 2016-06-10 21:45:03.753
CAC_UnLocked Connor’s Door Lock is opened false 2016-06-09 15:37:57.741 2016-06-11 12:02:37.476
CACDoorOpen Whenever Connor’s Door is opened whether is armed or disarmed false 2016-06-11 10:08:57.708 2016-06-11 12:02:43.374
CACLaskoOn Whenever the Connor’s LASKO is turned on true 2016-06-11 12:02:42.405 2016-06-09 15:32:50.850
CACLightOn1 Whenever the Connor’s Light is turned on false 2016-06-11 10:08:58.100 2016-06-11 12:02:58.758
DRLightOn Whenever the Dining room light is turned on false 2016-06-11 12:27:50.989 2016-06-11 12:30:50.379
ECDoorOpen Whenever Eric’s Office Door is opened whether is armed or disarmed false 2016-06-11 10:07:45.252 2016-06-11 10:08:00.275
FDLockButtonPressed Front Door: Lock button is pressed true 2016-06-02 22:43:20.915 0
FDLSPinEntered PIN Code #4 is entered on Front Door false 2016-05-06 10:18:59.684 2016-06-02 22:43:28.445
FDOpen Whenever Front Door Sensor is opened whether is armed or disarmed false 2016-06-11 12:27:49.617 2016-06-11 12:41:23.180
FDPINEntered PIN Code #* is entered on Front Door true 2016-06-02 22:43:28.445 0
FDTCPinEntered PIN Code #2 is entered on Front Door false 2016-05-30 19:48:18.515 2016-06-02 22:43:28.445
FDUnlocked Front Door is opened true 2016-06-11 08:12:25.617 2016-06-10 13:46:41.399
GarageDoorOpen Whenever GD Sensor is opened whether is armed or disarmed false 2016-06-11 07:58:45.938 2016-06-11 08:02:35.713
GarageLightOn Whenever the Garage Lights is turned on false 2016-06-11 08:19:05.903 2016-06-11 08:29:32.798
GBedDoorOpen Whenever Guest Bedroom Door is opened whether is armed or disarmed true 2016-06-11 08:04:45.455 2016-06-10 17:25:03.108
GoodPINsEntered PIN Code #1,3,4,8 is entered on Connor’s Door Lock false 0 2016-06-08 13:05:07.779
IRBeamTriggered Whenever the IR Beam is turned on false 2016-06-11 12:41:16.462 2016-06-11 12:41:20.104
IsNight Day or Night indicates Night time. false 2016-06-10 20:26:40.180 2016-06-11 06:32:15.205
MACDoorOpen Whenever Michaela’s Door is opened whether is armed or disarmed false 2016-06-11 12:27:09.555 2016-06-11 12:27:31.108
MACRoomLightOn Whenever the Michaela’s Room Light is turned on false 2016-06-11 12:27:22.596 2016-06-11 12:27:33.966
MBRFrenchOpen Whenever Master Bedroom French Doors is armed and opened false 2016-06-11 06:53:40.999 2016-06-11 06:55:24.516
SmokeDetectorAlarming Whenever Smoke Detector is opened whether is armed or disarmed false 2016-06-10 22:01:46.340 2016-06-10 22:01:56.148
UDMSPinEntered PIN Code #3 is entered on Utility Door false 0 2016-06-11 08:01:10.921
UDOpen Whenever Utility Exterior Door is opened whether is armed or disarmed false 2016-06-11 08:19:03.097 2016-06-11 08:19:13.174
UDPINEntered PIN Code #* is entered on Utility Door true 2016-06-11 08:01:10.921 0
UDTCPinEntered PIN Code #2 is entered on Utility Door true 2016-06-11 08:01:10.921 2016-06-09 09:10:49.423
UDUnlocked Utility Door is opened true 2016-06-11 08:19:01.710 2016-06-11 08:03:20.025
URLightOn Whenever the Utility Room Light is turned on false 2016-06-11 11:13:44.224 2016-06-11 11:44:38.596
Schedules
Name On Type On Time On Days Random On Delay Off After Type Off Time Off Days Random Off Delay State Last On Last Off
AutoArmEvery1hrs Interval 01:00:00 None Interval 1:00 None false 2016-06-11 14:00:00.100 2016-06-11 14:01:00.100
Device Properties
Name Device Name Device Variable Value Last Change Previous Change
ArmedMode Partition 1 DetailedArmMode Ready 2016-06-11 08:19:09.539 2016-06-11 08:19:03.261
MACDoorOpen1 Michaela’s Door Tripped 0 2016-06-11 12:27:31.157 2016-06-11 12:27:09.600
Conditions
Name Repeat Expression State Last True Last False
MACLightOn No MACDoorOpen false 2016-06-11 12:27:09.557 2016-06-11 12:27:31.110
HallLightOn No CACDoorOpen OR MACDoorOpen or GBedDoorOpen true 2016-06-09 15:38:06.063 2016-06-09 15:33:37.046
FPLightOff Yes !IsNight true 2016-06-11 06:32:15.211 2016-06-10 20:26:40.189
FPLightDimOnGDClose No IsNight and !GarageDoorOpen false 2016-06-10 20:26:40.190 2016-06-11 06:32:15.220
FPLightDimAtNight No IsNight false 2016-06-10 20:26:40.201 2016-06-11 06:32:15.221
FPLightOn No (IsNight and GarageDoorOpen) or (IsNight and FDOpen) false 2016-06-09 20:26:17.246 2016-06-09 21:00:20.707
FPDimOnFDClose No IsNight and !FDOpen false 2016-06-10 20:26:40.219 2016-06-11 06:32:15.225
GarageLightOn1 No !GarageLightOn and (GarageDoorOpen and IsNight) or (!GarageDoorOpen and UDOpen) false 2016-06-11 08:19:03.105 2016-06-11 08:19:13.182
URLightOn1 No UDOpen and !URLightOn false 2016-06-11 08:19:03.114 2016-06-11 08:19:06.391
DRLightAutoOn No !DRLightOn and UDOpen and GarageDoorOpen and (GarageDoorOpen; UDOpen < 5:00)or FDopen false 2016-06-11 12:27:49.629 2016-06-11 12:41:23.194
AutoLockDoors No !GarageDoorOpen true 2016-06-11 08:02:35.748 2016-06-11 07:58:45.959
AutoArmAllDoorsLocked No !UDUnlocked and !FDUnlocked and !BDUnlocked and ArmedMode ne “Stay” false 2016-06-11 06:49:13.168 2016-06-11 06:49:13.792
ECLightOn No ECDoorOpen false 2016-06-11 10:07:45.266 2016-06-11 10:08:00.288
ECLightOff No !ECDoorOpen true 2016-06-11 10:08:00.289 2016-06-11 10:07:45.271
BPLightsOn No IsNight and BDOpen false 2016-06-10 21:44:59.207 2016-06-10 21:45:09.891
MAClightOff No !MACDoorOpen true 2016-06-11 12:27:31.123 2016-06-11 12:27:09.573
CACLightOn No CACDoorOpen and !CACLaskoOn false 2016-06-11 10:08:57.723 2016-06-11 12:02:42.420
CACLightOff No !CACDoorOpen true 2016-06-11 12:02:43.390 2016-06-11 10:08:57.727
MACLightOn10pct No MBRFrenchOpen and !MACRoomLightOn false 2016-06-11 06:53:41.028 2016-06-11 06:55:14.151
MACLightOff10pct No !MACDoorOpen and !MBRFrenchOpen true 2016-06-11 12:27:31.129 2016-06-11 12:27:09.576
AutoArmHourlyAtNight Yes IsNight and (ArmedMode ne “Stay”) and AutoArmEvery1hrs false 2016-06-11 00:00:00.999 2016-06-11 14:01:00.118
GBLightOn No GBedDoorOpen true 2016-06-11 08:04:45.482 2016-06-10 17:25:03.131
GBLightOff No !GBedDoorOpen false 2016-06-10 17:25:03.132 2016-06-11 08:04:45.496
IRBeamTripped No IRBeamTriggered false 2016-06-11 12:41:16.491 2016-06-11 12:41:20.122
CACLaskoAutoOn No !CAC_UnLocked true 2016-06-11 12:02:37.496 2016-06-09 15:37:57.774
CACLaskoAutoOFF No CAC_UnLocked false 2016-06-09 15:37:57.775 2016-06-11 12:02:37.500
GBedLightAutoOn No GBedDoorOpen true 2016-06-11 08:04:45.497 2016-06-10 17:25:03.137
SmokeDetectorAlarmingEmail No SmokeDetectorAlarming false 2016-06-10 22:01:46.381 2016-06-10 22:01:56.294
SmokeDetectorNotAlarmingEmail No !SmokeDetectorAlarming true 2016-06-10 22:01:56.295 2016-06-10 22:01:46.388
GBedLightAutoOff No !GBedDoorOpen false 2016-06-10 17:25:03.138 2016-06-11 08:04:45.505
disarmPin Yes BDPINEntered or FDPINEntered or UDPINEntered true 2016-06-11 08:01:10.974 2016-06-02 22:31:21.798
Actions
Actions for Condition: AutoArmAllDoorsLocked
Device Actions:
Immediate
Device Action Arguments
Partition 1 RequestArmMode State=Stay PINCode=8169
Actions for Condition: AutoArmHourlyAtNight
Device Actions:
Immediate
Delay 15
Back door SetTarget newTargetValue=1
Delay 30
Front Door SetTarget newTargetValue=1
Delay 45
Utility Door SetTarget newTargetValue=1
Actions for Condition: AutoLockDoors
Device Actions:
Delay 15
Delay 30
Delay 45
Actions for Condition: BPLightsOn
Device Actions:
Immediate
Back Porch Lights SetTarget newTargetValue=1
Actions for Condition: CACLaskoAutoOFF
Device Actions:
Immediate
Connor’s LASKO SetLoadLevelTarget newLoadlevelTarget=0
CAC Blacklight SetTarget newTargetValue=0
Actions for Condition: CACLaskoAutoOn
Device Actions:
Immediate
Connor’s LASKO SetLoadLevelTarget newLoadlevelTarget=100
CAC Blacklight SetTarget newTargetValue=1
Actions for Condition: CACLightOff
Device Actions:
Immediate
Connor’s Light SetLoadLevelTarget newLoadlevelTarget=0
Actions for Condition: CACLightOn
Device Actions:
Immediate
Connor’s Light SetLoadLevelTarget newLoadlevelTarget=100
Actions for Condition: disarmPin
Device Actions:
Immediate
Partition 1 RequestArmMode State=Disarmed PINCode=2476
Actions for Condition: DRLightAutoOn
Device Actions:
Immediate
Dining room light SetTarget newTargetValue=1
Delay 03:00
Dining room light SetTarget newTargetValue=0
Actions for Condition: ECLightOff
Device Actions:
Immediate
EC Office Fan SetTarget newTargetValue=0
EC Office Light SetLoadLevelTarget newLoadlevelTarget=0
Actions for Condition: ECLightOn
Device Actions:
Immediate
EC Office Light SetLoadLevelTarget newLoadlevelTarget=100
Actions for Condition: FPDimOnFDClose
Device Actions:
Immediate
Front Porch Lights SetLoadLevelTarget newLoadlevelTarget=10
Actions for Condition: FPLightDimAtNight
Device Actions:
Immediate
Actions for Condition: FPLightDimOnGDClose
Device Actions:
Immediate
Actions for Condition: FPLightOff
Device Actions:
Immediate
Front Porch Lights SetLoadLevelTarget newLoadlevelTarget=0
Actions for Condition: FPLightOn
Device Actions:
Immediate
Front Porch Lights SetLoadLevelTarget newLoadlevelTarget=100
Actions for Condition: GarageLightOn1
Device Actions:
Immediate
Garage Lights SetTarget newTargetValue=1
Actions for Condition: GBedLightAutoOff
Device Actions:
Immediate
Guest Bedroom Light SetLoadLevelTarget newLoadlevelTarget=0
Guest Bedroom Fan SetTarget newTargetValue=0
Actions for Condition: GBedLightAutoOn
Device Actions:
Immediate
Guest Bedroom Light SetLoadLevelTarget newLoadlevelTarget=100
Actions for Condition: HallLightOn
Device Actions:
Immediate
Hallway Light SetTarget newTargetValue=1
Actions for Condition: IRBeamTripped
LUA:
luup.inet.wget(“http://192.168.1.81/admin?camera=Porch44&trigger&user=”,10)
luup.call_action(“urn:upnp-org:serviceId:RGBController1”, “StartAnimationProgram”, {programName = “LAPD”}, 178)
luup.call_action(“urn:upnp-org:serviceId:RGBController1”, “StartAnimationProgram”, {programName = “LAPD”}, 179)
Device Actions:
Delay 45
Controller FR 178/5 StopAnimationProgram
Controller KIT 179/7 StopAnimationProgram
Actions for Condition: MAClightOff
Device Actions:
Immediate
Michaela’s Room Light SetLoadLevelTarget newLoadlevelTarget=12
Michaela Floor Light SetLoadLevelTarget newLoadlevelTarget=12
Actions for Condition: MACLightOff10pct
Device Actions:
Immediate
Michaela’s Room Light SetLoadLevelTarget newLoadlevelTarget=0
Michaela Floor Light SetLoadLevelTarget newLoadlevelTarget=0
Actions for Condition: MACLightOn
Device Actions:
Immediate
Michaela Floor Light SetLoadLevelTarget newLoadlevelTarget=100
Michaela’s Room Light SetLoadLevelTarget newLoadlevelTarget=100
Actions for Condition: MACLightOn10pct
Device Actions:
Immediate
Actions for Condition: SmokeDetectorAlarmingEmail
Device Actions:
Immediate
VeraAlerts SendAlert Message=SMOKE ALARMS!! Recipients= HouseModeMask=
Actions for Condition: SmokeDetectorNotAlarmingEmail
Device Actions:
Immediate
Email Notification SendEmail Subject=Smoke is all clear Recipient_eMail=REDACTED@email.com Recipient_Name=Eric Message=
Actions for Condition: URLightOn1
Device Actions:
Immediate
Utility Room Light SetTarget newTargetValue=1
Delay 05:00
Utility Room Light SetTarget newTargetValue=0
