I have a Vera 3 on UI5, things works fine but I need to modify a few things but whenever I click on the pleg device and tried to modify it, it keeps on saying “opening Pleg…XXX” forever.
Check to see if you have auto update turned on ?
You need to be running version 7.x of the plugins for UI5.
See:
http://forum.micasaverde.com/index.php/topic,14446.0.html
[hr]
You should be able to fix things by restoring from a backup before things got screwed up.
I did have it checked, on version 7.47*
And what about PLC ?
Did you try restoring from a backup ?
Both are the same version
PLEG has been working for the longest time, I have not do anything to it for over 6 months. Not sure of which backup to use at this point. I remember running into this issue awhile ago but left it alone since everything was working. I need to add another pleg device now. It added OK but it’s giving me a max license error so I gotta make sure my license is in there as well as modify the newly added PLEG device.
Sounds like you just need to enter the licence … you can go to the registration server to get your previous license if you lost it.
If you do not have a good backup … where you know everything is working … you can try to re-install the software … using the previous link I sent you.
Backup first!!!
I’m getting the following error when issuing the command. Vera does seems to response to something just making sure this isn’t an issue
[sup]This page contains the following errors:
error on line 2 at column 50: xmlns:u: ‘Unknown Service’ is not a valid URI
Below is a rendering of the page up to the first error.[/sup]
went through all the steps and is now able to navigate around. Thanks for your help
sorry for the costant back and forth. I had 3 devices in PLEG, I added a 4th one after I fixed the issue and now it’s telling me that I’ve maxed out.
1 license gives me 4 devices right?
