PLEG - Export condition
wonder if anyone can advise what the export option does when defining a condition? And how it should be used?
I’m hoping it means that you can export the results of a condition, so that they could be used in other PLEG devices?
Currently I use virtual devices (switchboard) to handle passing conditions from one PLEG device to another, but if I could use an exported condition, I could get rid of a lot of my virtual devices.
Thanks in advance,
Tony
That is exactly what it is for. I created a condition in one PLEG called “QuietTime” and I pull that into my other PLEGs. You do that by referencing the other PLEG and importing the exported condition in the Device Properties section. I find that it always gets imported as a string, so I convert back to boolean with another condition…
Thanks, that’s great! trying to reference it directly in a condition, so was missing the device property part.
Thanks for your help, much appreaciated.
Tony
