Question for RTS
I have 1 Vera3 and 3 VeraLites, plus a spare Lite that is not connected currently.
The Vera3 is what I consider the master and sees all devices from all Veras; the others only see their own(Z-wave) devices.
All apps are installed on the Vera3(master). The others simply have all z-wave devices.
All scenes on the master Vera3.
I have about 65 Zones on my alarm panel connected by AD2USB, including about 10 motions and 11 exterior doors.
I have setup a few PLEG scenarios for “door left open”, “turn on/off light based on motion”, etc.
I want to add “door left open” so that all 11 exterior doors are monitored, all 10 motion sensors turn on/off lights, and I want to add “lock door within 1 minute only if door is closed”.
It’s my understanding that this may be too much for a single PLEG. Is this true?
If so, should I, (A) create a 2nd PLEG on the same Vera3?
Or
Should I, (B) move my AD2USB to the spare Vera, and add this Vera(with all alarm sensors) to all the others, so that each Vera3/VeraLite can run PLEG on it’s own for the devices in those areas, and thus “split the load” amongst all the Veras?
Do you think I will run out of memory on option A? If not, will option A become slow because of all the inputs and conditions?
Do you think I will see a performance/speed boost by having each vera share the load?
