PLEG and GCAL
Is the following possible?
One Gcal plugin that returns the actual word in the calendar
PLEG to run scene based on AND/OR multiple keywords
Example. Gcal reading a single calendar. PLEG set to trigger a scene if (gcal = keyword1) or (Gcal = keyword2) this would save the numerous single use Gcal plugins that now need to be defined.
Yes. You can set a PLEG input that looks for “A calendar event matches keyword” and specify the keyword to look for.
A word of caution - It looks to me like the GCal will behave like any other sensor - once it’s tripped, it won’t trip again until it’s not tripped. So if you have events that overlap or happen at the same time, you’ll need to use separate GCal instances.
