Richard,
Please fix this immediately. Has happened every morning since I completely rebuilt PLEG at 6.5 - it makes PLEG unusable if I cannot rely on PLEG working . NONE of the Actions trigger when it is in this state… thus, my alarm system does not function.
The only way to get it functioning again has been to unplug/replug
Luckily, this has not occurred during the day but I cannot wake up to an alarm going off because my motion sensors were not turned off and triggered by my 4 year old.
i appear to be having the same issue with 6.6 on only one of my plegs… I have 3 total and I get the failure on just one of them. What seemed to trigger it was I added a condition only to it… removing the condition did not change the failure. My 2 other plegs work, however this one does not… I really don’t want to rebuild it if I don’t have to since I just put a lot of code into it for my HVAC.
You can restore from the previous nights backup …
Or if you happened to have done a PLEG backup (new 6.6 feature) before you started to make some changes … you should be able to restore that device.
The error in the log does not seem to match the code … it seems to want to start previously delayed actions before the restart.
You might:
Do a browser refresh F5
Goto the advanced tab … Look at the variable: ActionsMap
If it’s not blank … save the value and post it back here.
I am having the same issue with PLEG as well. Seems to have started with the last day or two and i have not made any changes to it to make it start doing this. I get a message at the top of the pages that states “Program Logic Event Generator[29] : Startup Lua Failed”. Im not sure what i should do i had just started to get a few conditions working this weekend and now nothing is working. i tried upluging my vera and pluging it back in with no luck.
Any help would be appreciated. I am still in the 30 day trial period and I want to make sure it will work for me before i pay for the license.
