"Please wait! Getting the name" Error
A light control panel (FXA-0404) is showing Please wait! Getting the name error.
If I copy the Capabilities variables from a similar panel (FXA-0600) the 0404 doesn’t show the error until next engine reload.
FXA-0404 Capabilities
211,156,1,4,16,3,L,R,B,RS,|32,34,37,39,43,45,89,90,94,96:2,112,114,115,119,122,129,133,134,136,
FXA-0600 Capabilities
211,156,0,4,16,3,L,R,B,RS,|32,37,39,43,96:2,112,114,134,136,
Log Extract
ZWJob_SendData::ReturnMessageNotReceived job job#3 :nameget node 3 dev:58 (0xef6928) N:3 P:38 S:5 Id: 3 to node 3 command 0x77/0x2 retries 0 of 2 quit 0 returned m_iFrameID 0 <0x2c917680>
ZWJob_SendData::ReceivedFrame ok job job#3 :nameget node 3 dev:58 (0xef6928) N:3 P:38 S:5 Id: 3 to node 3 command 119/2 took 1 retries resend: 0 waiting 119/3 got 0 <0x2c117680>
ZWJob_SendData::ReturnMessageNotReceived job job#3 :nameget node 3 dev:58 (0xef6928) N:3 P:38 S:5 Id: 3 to node 3 command 0x77/0x2 retries 1 of 2 quit 0 returned m_iFrameID 0 <0x2c917680>
ZWJob_SendData::ReceivedFrame ok job job#3 :nameget node 3 dev:58 (0xef6928) N:3 P:38 S:5 Id: 3 to node 3 command 119/2 took 2 retries resend: 0 waiting 119/3 got 0 <0x2c117680>
ZWJob_SendData::ReturnMessageNotReceived job job#3 :nameget node 3 dev:58 (0xef6928) N:3 P:38 S:5 Id: 3 to node 3 command 0x77/0x2 retries 2 of 2 quit 0 returned m_iFrameID 0 <0x2c917680>
ZWJob_ConfigureNode::ChildChanged aborting job#2 :conf_jh#3 dev:58 (0xee5f28) P:39 S:5 Id: 2 for job#3 :nameget node 3 dev:58 (0xef6928) N:3 P:38 S:5 Id: 3 <0x2c917680>
ZWJob_SendData::JobFailed job#3 :nameget node 3 dev:58 (0xef6928) N:3 P:38 S:3 Id: 3 Priority 38 <0x2c917680>
Any ideas on how to solve this error?
HI
I have this error have your corrected this problem?
Thamks
I have this problem as well. Anyone found a solution?
