Does this message indicate my system waiting on the Vera backend? I have been unable to configure some of my First Alert Z-combos to UI7 and Vera Plus. They get stuck on this message.
I have tried removing and re-including. I have waited over night for the device to include with no luck.
I had exactly the same problem with fibaro motion sensors v3.2 (They still do not work in Vera correctly).
The only way I could configure associations and add in extra parameters was to click the configure node now button in advanced/commands.
Hit that and then wake device.
Regards, Rich.
[quote=“RichDC, post:2, topic:191638”]I had exactly the same problem with fibaro motion sensors v3.2 (They still do not work in Vera correctly).
Regards, Rich.[/quote]
Thanks!
This fixed my qubino flush relay that was stuck in some annoying “Please wait, getting manufacturer” message.
Moved my Vera so it was close to the relay then activated “Configure node now” and it is fixed
