Let me start off by saying im a newbie with this product. Im trying to control an ir controlled AC unit using the vera 3 with a Itach as my blaster. i created a few scenes to control my unit but on top of my dashboard reads ERROR: error in lua for scenes and events. Can someone please give me an example of how to correctly format my lua coding? Thank you
Maybe this helps:
http://wiki.micasaverde.com/index.php/Luup_Scenes_Events
I basically think you shouldn’t need a lot of coding for such simple scenes. If you go to “Apps=>Develop Apps=>Test Luup Code” on your vera, you can test code. Do use http://YOURVERAIP/cgi-bin/cmh/log.sh?Device=LuaUPnP to see the log of your vera, that way you can find errors.
Or you could post what you already coded and then we could maybe have a look at it.
I think that url only works if you are connected to the same local network that your vera is on.
