Hi guys - Im new to the MCV world so bear with me…
I purchased a Veralite and several HA05 screw in modules. I am having an issue getting them to pair. I log into the vera and go to add device. I follow the on screen instructions and select option 1 to pair. As directed by the onscreen instructions I hit the program (on/off) button on the ha05 and then click Next on the vera… Shortly thereafter I get a message indicating "I dont see that you added any new devices. Ive tried this with several different HA05 devices thinking that one may be defective. Ive also tried resetting and then even factory resetting the vera to no avail.
I dont know if I am doing something wrong or if something may be wrong with my vera.
Can someone please point me in the right direction?
Both the Vera and the lamp has power. The Vera was actually sitting on top the lamp when i tried. Im going to try the “advanced add” when I get home tonight.
I have a Vera 2 (not a Vera Lite) and I’ve got to admit that I’ve never found software includes to be reliable. I’ve always found hardware includes to be reliable though (that is, using the buttons on the Vera unit instead of the UI). Building on what others have suggested, I’d advise the following:
[ol][li]Set the Vera unit into exclude mode (via the hardware button on the top)[/li]
[li]Press the button on the HA-05 to exclude it.[/li]
[li]Reboot the Vera Lite.[/li]
[li]Set the Vera unit into include mode (via the hardware button on the top)[/li]
[li]Press the button on the HA-05 to include it.[/li][/ol]
[quote=“DaveL17, post:7, topic:174373”]I have a Vera 2 (not a Vera Lite) and I’ve got to admit that I’ve never found software includes to be reliable. I’ve always found hardware includes to be reliable though (that is, using the buttons on the Vera unit instead of the UI). Building on what others have suggested, I’d advise the following:
