Simple problem: wall switch controls an overhead light. I now want it to also control a wall sconce. Running romex is looking more and more promising, but its an outside wall with a vaulted ceiling so it would be a huge PITA to do…
Requirements:
Must be fast - no polling. Both dimmers must be synchronized, no double-tapping to turn on the other light.
Preferably not rely on a controller.
Nice to have: remote to turn on/off and change brightness.
I’ve bought $300 in stuff to try to make this work and I’ve failed so far. Whatever I don’t need is going back.
Vera Lite
Linear WD500Z-1 Dimmer switch
Aeotec Micro Smart Dimmer
Aeotec Minimote
I also have (probably going back, as they aren’t dimmers):
Linear FS20Z
Aeotec DSC26103 In Wall Micro Switch
Probably also going back:
Aeotec Z-Stick S2 USB and the demo version of InControl Home Automation
I think what I want is to associate the Aeotec dimmer with the linear dimmer switch but I can’t seem to get it to work. I’ve tried setting up associations with the Z-stick, again with the mini mote and a third time with the veralite. I can’t get the linear dimmer to control the aeotec dimmer at all, even with double taps (group 2?)
Do I have the wrong hardware? I’m starting to think this Linear stuff is junk and I should just get a GE dimmer switch or something.
