Fired up mControl tonight for the first time in awhile and loaded the vera luup driver. below is a screen shot
Hi mate please can you expand on this as I too have mControl but moved to vera due to the reliabilty issues but miss the MCE interface
mControl uses the Vera Luup driver from the driver library. You input your IP address and then restart the mControl Server. From there you can add your device. Just a general note the driver is a year old and needs to be updated. I needs to have door locks added, etc. I should be simple for mControl to update the driver.
Hi
Did you find issues with the status feedback of devices between Vera and mControl ?
To be honest I have not played with mControl in over a year.
