Playbar support
After few exchanges in the following topic ( http://forum.micasaverde.com/index.php/topic,25243.msg242413.html#msg242413 ) I have updated my code in order to have a correct group management even with Playbar zones.
After a positive feedback, I have now committed my changes and the new ZIP file is available here: http://code.mios.com/trac/mios_sonos-wireless-music-systems/changeset/218/trunk?old_path=%2F&format=zip
If you have the official 1.3 version installed, you only need to upload the updated files I_Sonos1.xml and J_Sonos1.js in the Vera (and of course reload your Vera).
Can users owning a Playbar make full tests with this development version: TTS, pause all, group/ungroup, … and give me feedback.
For the support of the Playbar audio input, there is apparently some to change.
Please provide the required information in this topic.
If someone has a Sonos Home Theater setup with a playbar + 2 Play:3 (or Play:1) as rear speakers, I would be interested that you provide the value of the variable ZoneGroupState (it is now available in the Help tab).
Let me know if such a setup is correctly managed by the plugin.
Without any feedback to this thread, I assume everything is working well with Playbar.
It is for me, I am still using the version that you had fixed for me a while back and is grouping and un grouping the playbar zone properly, I do not have it setup with left and right speakers though, just a sub.
