i want to be sure that a specific devices is reachable. Therefore i tested the poll action. But this action not always returns that the device is reachable, although it is connected. is there another way to check by code if a device is reachable?
The devices provide an action StressTest. If i call this action comments are shown like āSent 10 direct pingsā¦ā. Is there a way to ping devices on my own?
Polling is the process where Vera requests information from a Z-Wave device about its current status, such as on/off, dim level, temperature, and so on.
Some devices, such as many battery operated sensors for example, will be in a low-power state most of the time and therefore are not listening to the network and cannot be polled at all.
However, you should receive a poll answer from a battery operated device if you wake it up manually by pressing the button on it just before polling it.
