Ping Sensor / UI3
I can’t get the Ping Sensor Plugin to work in UI3. I upload the Luup Files under MIOS developer, but when I create a device there (choosing D_PingSensor.xml as UpnpDevFilename and I_PingSensor.xml as UpnpImpFilename) I get a device that has no controls at all. I see variables but I don’t find a way to use the device in scenes…
Seems that I am struggling at the very beginning.
Any help appreciated!
after a long time off I decieded to check back this forum again and I stumbled upon your message.
I updated my vera to UI3 and decided within 3-4 mins. to revert it back to UI2.
Long story short:
I’m not able to debug it and not willing to install UI3 ever again. But I’ve got an idea about this.
If UI3 suffers from the same behaviour like UI2 does, it will probably show up controls when you reboot vera.
(At least the Lua engine has to be restarted once or twice as I remember, and rebooting would have the same effect)
hope it helped,
Ted
Hi Ted,
thanks for your answer - actually I did the same and switched back to UI2…
Did the plugin had the new magic string: something.json?
I setup UI3 on my second Vera, can’t make myself work with it for more then few minutes at once though…
