Philips Hue does not work in Scenes
I got my philips hue working great, I can dim/color/on/off etc.
BUT when I make a manual scene to call a favorite Hue-scene It says successful but nothing happens with my Hue-bulbs. It does turn on/dim my other z-wave equipment.
Tried with diffrent hue-scenes (both made from vera and factory-scenes).
So my hue works but I can not automate anything.
Im lost :frowning:
Same here :frowning:
Same here.
Try this- first you need to do a little legwork. Open the Philips Hue plugin (not a bulb, the controller). Make sure your desired scene is in the “Hue Presets List”. If not, add it. Then click on the “>”, then “advanced”, then “variables”. Scroll down to “Bridgescenes”. There should be a lot of text. I copied and pasted into a word file. It’s basically a comma delimited spreadsheet. For each scene, there is a 15 digit code inside quotation marks. Copy the 15 digits without quotes. Open your scene and go to the Advanced editor. Scroll down to the Hue controller. Paste the 15 digit code into the Scene: box. It worked for me- it was in another thread here somewhere. Hope this helps.
