I’m trying to get the Philio Smart Button working with my Fibaro FGD-212 and for some reason there doesn’t seem to be any communication?
I found this:
http://forum.micasaverde.com/index.php?topic=36740.0
which actually got me going while testing with the RGBW controller from Fibaro and it works fine; turns LED strip lights on/off and dims no problem.
When I associate with the FGD-212 through same process: Device Options → Group 2 → Check Box of FGD-212 → wake up Philio for config
nothing happens? I can see the red LED on the Philio flashes when set to On/Off, Off, or Dimmer areas but that’s it - the light connected to the FGD-212 doesn’t come on or go off or dim. In fact the Vera doesn’t even say “Transmit Success” as it does with the RGBW module of Fibaro.
It is really odd!! My Vera version is the Edge running UI7, so everything is at its latest, so why will the Philio only work with one device but not the other?
I’ve also attempted to get it working in simple switching mode with the FGS-2x3 Single switch module too which also didn’t work…???
Is there any extra setting or config needed for these devices I wonder?
Roughly translating this posting to English: https://forum.m.nu/controllers/philio-psr04-smart-color-button-t4775.html claims that it can be done, but it doesn’t really suggest how ![]()
Any help would be appreciated ![]()
