I have a philio pan04-1b model connected to a vera plus controller and a normal on/off wall switch my problem is that when
i turn the lights on/off from the wall switch i take more the 10 minutes to the controller to update the right status of the light
how can i fix this or how do i make the controller or the model update the status more often…?
That’s because the device does not support “Instant Status”
You are left to the polling interval.
You can lower the polling interval … but it’s not intuitive how to change it and changing it can make your system unstable.
(i.e. the polling interval of 5 minutes DOES NOT mean it will poll every 5 minutes)
If you really want to know that the switch was changed instantly you should get a switch that supports the instant status.
You might try making sure that you have an association setup in group 1 for the controller and that parameter 3 is setup to monitor the relay of interest. I’ve never used this device, so I have no direct experience, but maybe this would help.
“association setup in group 1 for the controller and that parameter 3 is setup to monitor the relay of interest”… can you explain more about this and how to do this…?
thank you.
