After device included got 4 devices shows up
Philio Both Loads
Philio Load one
Philio Load two
Philio Pan04 Relay Smartswitch with power meter.
And all working fine some time. Philio Pan04 Relay Smartswitch show power load in real time.
Then suddenly Smartswitchs appears on other child devices.
Philio Both Loads show 30 Kwh some frozen value
Philio Load one show 30 Kwh some frozen value
Philio Load two show 0 Kwh
Philio Pan04 Relay Smartswitch show correct power load.
Normal working config:
"id": "48",
"device_type": "urn:schemas-upnp-org:device:BinaryLight:1",
"room": "0",
"id_parent": 33,
"disabled": 0,
"device_file": "D_BinaryLight1.xml",
"impl_file": "",
"manufacturer": "",
"model": "",
"altid": "e1",
"ip": "",
"mac": "",
"time_created": "1392733232",
"states": [
"service": "urn:micasaverde-com:serviceId:ZWaveDevice1",
"variable": "ManufacturerInfo",
"value": "0,0,0",
"id": 0
"variable": "Capabilities",
"value": "211,156,1,4,16,1,L,R,B,RS,|37,50,",
"id": 1
"service": "urn:upnp-org:serviceId:SwitchPower1",
"variable": "Status",
"value": "1",
"id": 2
"service": "urn:micasaverde-com:serviceId:EnergyMetering1",
"variable": "KWH",
"value": "0.3800",
"id": 3
"variable": "KWHReading",
"value": "1393336995",
"id": 4
Config with frozen kwh value:
"id": "48",
"room": "0",
"id_parent": 33,
"disabled": 0,
"impl_file": "",
"manufacturer": "",
"model": "",
"altid": "e1",
"ip": "",
"mac": "",
"states": [
"value": "0,0,0",
"id": 0
"id": 1
"id": 2,
"value": "0"
"variable": "KWH",
"id": 3,
"value": "0.5000"
"id": 4,
"value": "1393389872"
"id": 251,
"variable": "Watts",
"value": "30"
"id": 253,
"variable": "Log",
"value": "30,30,30,1393389000,1"
"id": 254,
"variable": "ActualUsage",
"value": "1"
"id": 174,
"variable": "Target",
"value": "0"
It happens 3 or 4 times in one month. All the time need to restore userdata.json to get it working again.
And power usage history are incorrect with incorrect values from frozen smartswitches.
Why smartswitches appears on child devices?
And if they appears, how to make it show correct values, will be great to see power metering on separate loads.
