Is it possible to perform simple arithmetic within PLEG ?
I’m using MultiString as a user friendly variable container, and need to add a temp. offest to a reading before applying it to a radiator thermostat.
thanks
thanks
PLEG can certainly perform arithmetic. Have you seen PLEG Basics?
You can add an offset in a Condition using a simple expression:
OffsetTemp MSTemp + 5
You can use a calculated value in an Action using the special {(expression)} syntax. So, to set a thermostat to the above calculated value you could use the Action:
MyThermostat SetCurrentSetpoint, NewCurrentSetpoint={(OffsetTemp)}
The expression can also include arithmetic so it could be:
MyThermostat SetCurrentSetpoint, NewCurrentSetpoint={(MSTemp + 5)}
Doh…Schoolboy error!
Have read the excellent PLEG Basics, but it only talks about arithmetic within conditions.
I did try it out but think I was using {(x)+(y)} rather than {(x+y)}
thanks ![]()
