Gang, i have a Pentair Easytouch in my house and want to integrate with Mi Casa Verde 3. Possible ? Tips ?
I also have a Pentair IntelliTouch and IntelliChem system and would love it if somebody came up with an app that could control Pentair Intellitouch & EasyTouch systems from within Vera. It would be great to use Vera to run/set the pool pump and light schedules, alert on chemical levels, and control pool lights and pool fountain valves. I am guessing their is already an API that the Screenlogic desktop program and iPhone apps use today to connect to pentair protocol adapter given you can connect on the local network or remotely.
Not a coder, but wish I was
www.pentairpool.com/products/automation-intellitouch-systems-79.htm
Your wish is my command.
[url=http://forum.micasaverde.com/index.php/topic,30275.0.html]http://forum.micasaverde.com/index.php/topic,30275.0.html[/url]
There is an interface written under the hood but the Intellichem data is not displayed. If you implement the plugin I will build a panel that will let you work with the Intellichem data just like the Intellichlor data does now.
