I’ve vera plus and i wondering how i can enable local authentication(username and password ) when accessing the vera via its local ip (http)?
thx.
thx.
You are not alone. This is an oft-requested feature.
Sadly, at the moment, you can’t.
For some time I had actually created something like this but it was pretty complicated: I had to create a proxy and used VLAN and firewall rules to force access to the vera through the proxy running nginx with password protection… I abandoned it eventually due to the complexity of the maintenance
Actually, you can enable local logins. Here’s a link that describes removing the login, so to enable logins, reverse the instructions: VeraBridge Credentials - #16 by Buxton - openLuup - Ezlo Community
© 2022 Ezlo Innovation, All Rights Reserved. Terms of Use | Privacy Policy | Forum Rules
