Panning/Tilting my VistaCam PT
When I attempt to pan/tilt my VistaCam PT - it pans and/or tilts all the way in the direction I indicated. How do I get the camera to stop panning once it reaches the view that I want?
I believe you are using the controls from UI5. So when you log into your dashboard, near the bottom of the screen you should see “Advanced Settings”.
Click on this and look at the URL in your browser. You will see it changes to UI6.
Go to the camera and view it from there. Then there is a stop button so you can line it up exactly where you want it.
