Lightning took out my Vera 2, but my six Panasonic cameras are still up and running (thru Viewnetcam).
I installed a new Vera Lite UI5 and I am struggling to connect the cameras to view in Vera. I have downloaded the Panasonic App, but can’t seem to get through the first page of setup.
All six cameras are apparently detected, but they are not showing the correct IP addresses assigned by the router.
Any help would be appreciated.
Thanks.
Try following this menu structure.
Devices > Add Devices > I want to add an ip camera.
Thanks… I did try that, but the IP addresses that Vera lists (six of them) do not match up with the actual IP address assigned to the cameras by the router. Each camera has a slightly different Login, so it’s difficult to simply guess at which one is which.
Maybe I should unplug all cameras, delete the App and start over, plugging one camera in at at time. But if the IP address doesn’t match router, I’m not sure how to get around that easily.
