I recently setup my Vera2 with a Panasonic webcam. It’s working well accessing the images through Mios.com from my computer, and iVera from my iPhone/iPad. But I would like to be able to also log into the camera directly so I can change settings, access the microphone, etc.
The camera is connected to Vera2 wirelessly, and Vera is connected to the router directly with a cable.
I would be logging in over the Internet, not locally.
You’ll need to either set up some sort of dynamic DNS (dyndns.com) if your router supports it and then forward the relevant ports to the internal address and port; or if you are no comfortable doing that, then it may be a bit more simple to just use the Panasonic camera site which is viewnetcam.com
Hello,
I am using Panasonic BL-C230A camera on viewnetcam.com and it is working fine.
I want to setup it on Mios.com . Will you tell me step by step instructions how to
setup it. I am using vera2 with Netgear WNR854T RangeMax router.
I have tried port forwarding and Upnp elable in setup menu of the router , but it won’t work
on mios dashbord.
