All devices seem to work properly except PAN06 dual switches from Philio that went back to an old problem. Impossible to control each switch in the device independently. Device appears as 4 devices and only the master reacts to ON/Off commands but activating/deactivating both switches simultaneously.
This problem appeared under UI5 when I initially installed the PAN06 units and it become fixed after installing the MIOS Update Utility Plugin.
Now, unther UI7 I removed and reinstalled this plugin, but with unsuccesfull result.
OP appears to be running UI7, while you are on UI5? OP appears to say the issue that once existed on UI5 has returned under UI7. Did you install the MiOS Update plug-in on UI5 and you are still seeing issues? (See the thread where you posted also.)
hi, has the issue been resovled with 1.7.388?
trying to make a choice whether to upgrade or stick to UI5 (working philio pan06 with update utility plugin)…
