Paired Schlage Not reachable
I paired my Vera2 and my Schlage a while ago. The lock is pretty far from the Vera so I added two Evlove wall switches (they support beaming) between the Schlage and the Vera. I was hoping that the Vera would now be able to speak to the Schlage but no luck. I see ‘getting name’ and then ‘unable to get any information on node’.
Do I need to do something to make the Schlage realize that it can talk through the newly added devices?
Happy New Year!
As I undarstand the devise has to be able to comunicate using secure mode. Only new devices can do it ò¿ó
Remove the lock (unpair it) and then re-add it, it should then see the new evolve switches as neighbors and hopefully fix the routing issue.
