Just bring the Vera close to the lock and put it into pairing mode. On lock do the same steps you listed in your post. Leave the Vera next to the lock for several minutes to allow the lock to fully pair.
I bring the vera to the lock. Press the add button( it starts blinking). Then I hit schlage button, enter the programming code(it also starts blinking). However, after about 30 seconds the lock stops blinking while the vera is still blinking.
It doesn’t pair and I’m not sure why the schlage lock times out. What am I doing wrong
The lock might think it is paired to another controller. Try to exclude the lock (same process just hit the minus button) and then try to pair it again.
[quote=“Jnickell100, post:3, topic:177122”]I must be doing something wrong.
It doesn’t pair and I’m not sure why the schlage lock times out. What am I doing wrong[/quote]
Did you press the Zero?
This is what I did:
On Vera
1.) Bring the vera (with an extention cord plugged in) near the touchpad, with the door open, and unlocked…
2.) do an exclude. (Device Tab on Vera, → Add New Device → Next to “Advanced Z-Wave devices” Press ADD
3.) on the bottom half, under “Any type of Z-Wave device which you can bring close to Vera”
Select, Exclude and With, Select “Full Power”
4.) Press the “Go” Button.
immediately on the door
5.) Press the Schlage Button - It Should lock
6.) Press the Schlage Button again, Input your Programming Code… THEN press Zero…
7.) Wait until the green check box shows on the Lock Touchpad.
On Vera
8.) do an Include. (Device Tab on Vera, → Add New Device → Next to “Advanced Z-Wave devices” Press ADD
9.) on the bottom half, under “Any type of Z-Wave device which you can bring close to Vera”
Select, Include and With, Select “Full Power”
10.) Press the “Go” Button.
11.) Press the Schlage Button - It Should lock
12.) Press the Schlage Button again, Input your Programming Code… THEN press Zero…
13.) Wait until the green check box shows on the Lock Touchpad.
14.) Then wait an Additional 10 minutes, just leave it there.
