What does RFXtrx receive from these, is it the signal from the clamp on the power cable to the Owl display, or some signal from the display?
If it is the signal from the clamp, is there any point in having the Owl display? Could you just buy a clamp and be done with it?
The Z-wave clamp monitors seem to cost ?70-90, whereas the electricity company gives out free Zigbee (rebranded Alertme.com) devices that I can’t receive data from and Owl also costs significantly less. What if anything do the Z-wave devices offer to justify their premium price? Two-way communication doesn’t seem to be an advantage here?
Thanks Bert, just to be 100% clear before I order, by sensor you mean the clamp? So I only need a clamp to send signals that can be picked up by the RFXtrx433e and the Vera plugin, not the whole Owl product with the display too?
For the benefit of others who have the same question, just the clamp sensor is required, which, in the case of Owl comes in two parts, the clamp and a transmitter unit. The display is optional as the RFXtrx will do the job of receiving the data sent by the transmitter.
Having said all that, it looks to me as though the CM180 includes both the clamp and three channel transmitter for less than the price of buying them separately! I’ve just ordered one, so will correct this if that is not the case…
