I’m having some confusing trouble with setting up Altsteon. I’ve copied over the files using WinSCP and setup alsteon.dev to 755. I’m trying to run the “/overlay/sbin/altsteon --help” command and getting the error “/overlay/sbin/altsteon: not found”
I’ve attached a screenshot from WinSCP confirming that the files are there - does everything look correct? Any ideas on what else I should try?
Alright, making some progress, but I feel like something is still incorrect. If I run “/overlay/sbin/altsteon.dev --help” I get the Help output. So does that mean the files have an incorrect file extension? Should I remove “.dev” from the two files? Thanks!!
