Thanks pgrover516…
Sounds good then, I can probably eve mount it on the west side of the house to protect it from nor’easters.
Nice thing is at that location it’s only about 18-20’ from Vera2 with only one outside wall to penetrate- so communication shouldn’t be an issue.
Thanks again for the info guys… looks like the HS-TS001 is the way to go!
The Everspring ST814-1 is rated to IP44. Operating range is 14’F - 122’F
With it’s exposed buttons and LCD display- the Everspring ST814-1 doesn’t look like it would last very long in an outdoor environment…
With it’s exposed buttons and LCD display- the Everspring ST814-1 doesn’t look like it would last very long in an outdoor environment…[/quote] I have the last generation of it working nicely outside for a couple years, read mounting in post above
