are there any ? ;D
I found this on ebay. It appears it would work with any camera that is that “round/ball” style.
I ended up buying an outdoor Foscam that works well…
Good Luck.
[url=http://www.ebay.com/itm/Foscam-Outdoor-Waterproof-Dome-Enclosure-for-Indoor-FI8918-FI8910W-FI9821W-CAMS-/160983164021?pt=US_Surveillance_Accessories&hash=item257b582475]http://www.ebay.com/itm/Foscam-Outdoor-Waterproof-Dome-Enclosure-for-Indoor-FI8918-FI8910W-FI9821W-CAMS-/160983164021?pt=US_Surveillance_Accessories&hash=item257b582475[/url]
thanks, which outdoor foscam did you buy ? and does all the functions work with it ? i`m not fixated on vistacam - its just that i would rather not run into any incompatibilities
I personally have not programmed the motion detect yet. I do have the camera installed, pan/tilt working, sensor recognized, preset camera position set, etc…So it appears everything fully integrated…
It is the Foscam F18919W
thanks that helps !
