Probably a dumb question but is it possible to have os.execute called from a Reactor activity? Currently I have a reactor that runs a scene that executes the script…
Cheers
C
Cheers
C
Oh yeah. It can be in scene Lua, or you can do it directly from a Run Lua action in the activity. Should not be a problem.
If you do it in Run Lua and you’re having trouble, add some print() statements, which will log to the “Events” section of the Logic Summary and may be a little easier to get to than using luup.log() and fetching the Vera log file. There’s also a Reactor.dump() function you can call to “stringify” a table, for example print(Reactor.dump(luup.devices))
For the hard of thinking, how do it in Run Lua?
I tried putting in os.execute etc etc but that’s not happy. I assume there’s something I need to warp it in and have no LUA ![]()
Cheers!
C
Hmmm… maybe a little more detail about what’s happening? It should be as simple as going into Activities, and under whichever activity applies, adding a “Run Lua” action, and in the script window typing something like:
os.execute("date")
or the slightly more verbose:
local st = os.execute("date")
print("The status of the command is " .. tostring(st))
…which should emit a message to logic summary, hopefully “The status of the command is 0” (0 = no errors).
How very odd. I tried that (before I asked the obviously dumb question) and it refused to accept it.
Works fine now!
As ever, thanks!
C
