Can anybody tell me which version of OpenWRT runs on the Vera system right now. I’ve not expanded the opkg repository list, but I’m wondering which repo I could use to add some additional software on the vera. I also use FHEM in my house to control FS20 and FHT devices. FHEM is an opensource package which needs Perl. I’d like to investigate whether I’m able to get FHEM running on the WRT and perhaps even get a plugin running so I can integrate it into the Vera websystem.
Thank you Rob!
Let’s hope it contains the packages I need. I’ll try to get a version of FHEM up and running that isn’t dependend on the PGM2 version and only has a cli version of FHEM. A nice place to start scripting upon ;D
Thanks for posting this, it definitely saved me building an OpenWRT build environment
If others are wanting to do the same, presuming you can reuse the trunk version as @whyter lists above, you can do the following (to install packages like [tt]tcpdump[/tt].
