I’m going to try something a little different. Now hosting turn-key Linux images. Each image comes with the following:
[1] openLuup release 8 & AltUI - most recent master versions.
[2] Debian Jessie 8 (headless) or alternatively Ubuntu Standard Server 15.10.
[3] Weaved (remote access to UI via Web and SSH) for select distros (limited support).
[4] Custom backup Bash script (performs backup of select files and has CL arguments which I’ll discuss later). Deprecated.
[hr]
Raspbian Jessie Lite (Debian 8, Lite calorie) 8 for the Raspberry Pi (2 and 3).
openLuup Version 8 (Master):
Direct Download Link: [url=https://1drv.ms/u/s!AowgRiTGGe1Ljr5whpvJeq-gtElHBQ]https://1drv.ms/u/s!AowgRiTGGe1Ljr5whpvJeq-gtElHBQ[/url]
260MB download (requires minimum of 4GB to store image). Requires 7-zip to unpack image.
[size=8pt]user: pi
password: raspberry
sudoer: yes (sudo su)
root: yes[/size]
resize partition, localization and password change utility: sudo raspi-config
Weaved configuration (remote connection): sudo weavedinstaller
[hr]
Ubuntu Standard Server 15.10 for the Raspberry Pi (2 and 3).
Removed: Will be updated to latest version at a later date.
000MB download (requires minimum of 8GB to store image).
[size=8pt]user: ubuntu
password: openluup
sudoer: yes
root: yes[/size]
[hr]
Debian Jessie Lite (Debian 8; Lite calorie) for the Odroid XU4.
000MB download (requires minimum of 4GB to store image).
[size=8pt]user: odroid
password: openluup
sudoer: yes
console login: root
console password: odroid[/size]
[hr]
Odrobian Vanilla (Debian 8; 5422) for the Odroid XU4.
password: openluup
sudoer: yes
console login: root
[hr]
Debian Server 8.4.0 (Clone) for Oracle Virtual Box
Direct Download Link: [url=https://1drv.ms/u/s!AowgRiTGGe1Ljr5vFWmnQthw5L4BJQ]https://1drv.ms/u/s!AowgRiTGGe1Ljr5vFWmnQthw5L4BJQ[/url]
452MB download (8GB max disk capacity, 1GB memory & 1 CPU); compressed using 7-Zip
[size=8pt]** Will not contain a backup shell script.[/size]
[size=8pt]user: test
password: openluup
sudoer: yes
console login: root
console password: openluup[/size]
[hr]
The end user can now download the image file from the URL provided above and load onto an Micro SD/eMMC or SSD(dependent on your hardware). Once that’s complete, load the storage media into their device then expand the partition and change your password/localization and enable the GUI (IF applicable, if you prefer). Weaved is installed and you must create an account with them before proceeding with the setup (weavedinstaller). I have created one scene to execute a custom shell script and perform a openLuup backup. You can obviously adjust this to your liking (days, weeks and specific time) and optionally do as you like with the payload (below). For now, I have the scene executing at midnight daily.
I’m looking to host more flavors (please comment here on what you’d like to have) and I will continue to update the images as Akbooer releases newer versions. That is, until an upgrade can be performed directly within openLuup. Please remember to thank Akbooer and amg0 for all their hard work as well as the developers who have provided their support.
[hr]
Edit [03-15-16] : Turn-key will have it’s own individual guide(s) as well as Linux (Aptitude). I hope this alleviates any confusion.
Edit [03-21-16] : Updated Linux_Aptitude guide for support of ’ /etc/cmh-lu > /etc/cmh-ludl/files ’ (symbolic link). release 1.3
Edit [03-21-16] : Added Odroid XU4 Debian Jessie 8 image for download.
Edit [03-21-16] : Added Odroid XU4 Odrobian Vanilla (Jessie) image for download.
Edit [03-22-16] : Guides for Raspberry, Odroid and Linux (Aptitude).
Edit [03-23-16] : Added Ubuntu Standard Server 15.10 image for download.
Edit [04-19-16] : Revised Linux Aptitude guide. Added Oracle Virtual Box Clone for Debian 8.4.0 Server.
Edit [05-04-16] : Removed Bitly which was causing issues with download links.
Edit [07-13-16] : Added VBox with openLuup v8 (Master). Future upgrades are handled by this release (big thanks AK)…
Edit [07-22-16] : Raspbian Jessie for Raspberry Pi (models 1,2 and 3) with master versions for both openLuup v8 and AltUI master.
Edit [09-22-17] : (Coming 09-24-17) Raspbian Stretch for the Raspberry Pi Model Zero/Zero W.
[hr]
Backup payload:
"version":"1127.031316",
"host":"openLuup",
"eth0":"10.0.4.122",
"user":"root",
"status":"0",
"detail":{
"description":"openLuup_Backup",
"abort_code":"0",
"abort_text":"nil",
"epoch":"1457918697",
"input":{
"arg1n":"backup path",
"arg1v":"",
"arg2n":"initiate failsafe",
"arg2v":"",
"arg3n":"output path",
"arg3v":"",
"arg4n":"unique disk id",
"arg4v":"",
"arg5n":"disk watch",
"arg5v":""
"output":{
"arg1v":"/etc/cmh-ludl/*.xml /etc/cmh-ludl/*.json /etc/cmh-ludl/*.lua /etc/cmh-ludl/icons/* /etc/cmh-ludl/cgi*/*",
"arg2v":"false",
"arg3v":"/home/pi/vera/backup/2016.03/week.11",
"arg4v":"859cf567-e7d3-4fa7-82b8-cb835cd272c6",
"arg5v":"95"
"disk":{
"uuid":"859cf567-e7d3-4fa7-82b8-cb835cd272c6",
"usage":"25",
"unit":"percent"
"memory":{
"total":"970813440",
"used":"104247296",
"free":"866566144",
"unit":"bytes"
"file":{
"filename":"1457918697[Mon]-openLuupBackup.tgz",
"filesize":"50171",
"unit":"bytes"
"distro":{
"description":"Raspbian GNU/Linux 8 (jessie)"
